Cimate control display light........mind of its own
The green backlight on my climate control panel works sometimes....then stops working....
Could it be a loose connection or something.....howeasy is it to remove and check the connections...
Its very easy to remove and has a plug at the back. Remove the plastic trim that surounds the sterio, climate and the storage hole then the climate control unit securing screws are exposed.
And the backlight is almost certainly one of the wires to the bulbholder, bulb loose in holder or a partially blown bulb.
cheers peeps
