Replacing rear bulbs
Hi All
Have a fabia vrs and need to replace my break light bulb, any help in accessing the rear cluster would be much appreciated.
The manual says to push the cover to the side carefully but had no luck
Matt
Open the boot and pull the boot lining back on the inside behind the light cluster, you will see the white bulb carrier, it unclips at the top.
haha genius
so 'push the cover to the side carefully' actually means 'pull back the felt lining'
easy fix
cheers
