speaker replacement
hello
Has anyone replaced the standard speakers on the superb? Is it worth doing and any suggestions as to what speakers would fit
Are the speakers the same as an equivalent ****at?
Any help gratefully received
hello
Can't help you with your question but is a "****at" a Passat you are not very happy with?
Just taking the mick - I too have big fingers that get it wrong consistenby (see what I mean)
Hi
Thanks for your reply! It seems that no-one has ever thought of replacing the standard issue speakers in a Superb... I will have to do some research and post my findings!
As for the ****at, well nothing against the car, but always used it as a derogatory name for said VW battle bus.
I owned one myself and had no complaints, took it to nearly 200k miles so cant have been too bad! :P
WEll said Duffelcoat.
I've definitely thought about it... it's on my to-do list. Or rather, I'll do it when mine fail!
I've only looked at the fronts but I suspect 17.5cm/ 6 1/2" components would fit in fine, perhaps with a ******ised adaptor from something else VAG. I suspect the rears would be 13cm/ 5 1/4".
I'll be amplifying them when I change them so I've got a raft of other problems to deal with... so perhaps in your research if you see an easy method of running new speaker cable I'd appreciate it :thumbup:
