vrs strut diameter
looking into ordering suspension, but there are 4 options for the vRS
option 1- front strut diameter-50mm/fr axle load 1060kg
option 2 -front strut diameter-50mm/fr axle load 1061kg
option 3- front strut diameter-55mm/fr axle load 1060kg
option 4- front strut diameter-55mm/fr axle load 1061kg
my car is registered 57 plate sept 07, 2.0TFSI
anyone any ideas
IIRC this has been an issue in the past and the only way to know is to measure it.
guess thats wht ill have to do,
question though, i never understand text speak, please explain IIRC, keep seeing it
If I Recall Correctly
If I Remember Correctly.;)
I believe it can be done from the VIN number and depending on where you are planning a purchase they should be able to advise.
p.s. My educated guess would be 55mm
IIRC - if I remember correctly
All I did was to pass on my chassis number to JKM - they did the rest. :)
Lee
makes sense that way
looking at the AP coilovers, going through reviews of it on mkv forums at the moment to make an educated decision
