done successfully
I copied contents to root of my 64gb type c usb stick formetted as exfat week ago and it still didnt update. Is your usb formatted as mbr or gpt?
Some additional 2026.06 updates (for some RoW countries) out:
Australia -> https://download.updateportal.skoda-auto.com/maps/OI_P177_AUS_202612_Offline_Update.zip
Asia -> https://download.updateportal.skoda-auto.com/maps/OI_P177_ASIA_202612_Offline_Update.zip
India -> https://download.updateportal.skoda-auto.com/maps/OI_P177_INDIA_202612_Offline_Update.zip
South America & Mexico -> https://download.updateportal.skoda-auto.com/maps/OI_P177_MRM4_SAM_202612_Offline_Update.zip
The _202612_ in the filename appears to be incorrect - but the file contents appears to contain June 2026 data...
Discovered via Skoda update portal.
Enjoy!
That's your Turkish success story I did a cut paste. Will let @MartiniB or @dugeem to discover the other RoW. That's serdar_18fr work above. Apparently it took 8 minutes and he left another 20 minutes to ensure everything was copied over. For those that don't have the possibility of connected services where they live its even more important.
Hi, I’ve been struggling with the update for quite some time—tried various USB drives and an independent shop using ODIS—but I’m still stuck on version 24.12. I have two options: sending the unit out for repair or flashing a US-to-EU conversion via the service menu. Does anyone happen to have the conversion package, but with a version newer than 24.12? I’m even willing to pay for it.
Probably your navigation FeCs if you are trying to load maps into that which dont tally with the country it was meant for. The give away is in your text.
Mib3 is locked down from tinkering. A good retrofitter with vag equipment would be able to do it. Some can do this stuff remotely if you buy the box. It was all put on a legitimate level for legitimate use. Audi / VW police it.
East Yorkshire Retrofit is such a company in the Uk. Abroad other companies exist. Turkey is another country where retrofitter unlock the infotainment unit for map updating. Vehicles which are exported secondhand from Europe are candidates. American services personal bringing their Vag cars are another.
So yes it all changed with mib3. No toolboxes due to better encyption and backdoors bolted which had been left open in mib2. Changing firmware also runs risks irrespective of maps since these units are now locked down so if there is an issue you can't dig yourself out. The firmware may only work with specific other updates elsewhere in the car to the control systems.
Edited by Tell
5 hours ago, Tell said:
Prawdopodobnie masz problemy z nawigacją, jeśli próbujesz wgrać mapy, które nie zgadzają się z krajem, dla którego zostały przeznaczone. Błąd jest w tekście.
MIB3 jest zablokowany przed manipulacją. Dobry fachowiec z wyposażeniem VAG byłby w stanie to zrobić. Niektórzy potrafią to zrobić zdalnie, jeśli kupisz boxa. Wszystko zostało zainstalowane legalnie i legalnie. Audi/VW to kontroluje.
East Yorkshire Retrofit to taka firma w Wielkiej Brytanii. Za granicą istnieją również inne firmy. Turcja to kolejny kraj, w którym firmy modernizacyjne odblokowują urządzenia multimedialne w celu aktualizacji map. Kandydatami są pojazdy eksportowane z Europy jako używane. Amerykańskie serwisy oferujące usługi personalne przywożące samochody VAG to kolejny przykład.
Tak, wszystko się zmieniło wraz z MIB3. Brak skrzynek z narzędziami ze względu na lepsze szyfrowanie i zablokowane tylne drzwi, które pozostały otwarte w MIB2. Zmiana oprogramowania sprzętowego również wiąże się z ryzykiem, niezależnie od map, ponieważ te urządzenia są teraz zablokowane, więc w razie problemu nie da się go samodzielnie rozwiązać. Oprogramowanie sprzętowe może działać tylko z określonymi aktualizacjami w innych częściach samochodu, dotyczącymi systemów sterowania.
The FEC codes have been checked, and no unlocking is required; the car originates from the EU market and has factory-installed navigation. I even had an active three-month subscription. The service center that inspected it specializes in retrofitting and converting VAG Group vehicles. They had European activation maps available—specifically version 24.1—but we didn't want to perform a downgrade for fear of causing damage. The maps were downloaded from the VW website using the VIN.
Edited by Krzsiek
Probably an issue with the firmware. I know early Cupras had issues. Think @MartiniB did as well on their Skoda. There is a conversation going between him and one other. Think they downgraded maps and then moved forward from memory. In the mib3 map posts.
Can i check fec with obd11? My car came with 23.11 maps and i sucessfuly updated to 25.8, 26.2 and now i cant update to 26.6
Well the question is whether the file allows the use of your FeCs. Now I was told how to find the allowed FeCs in the presented map file for mib2 high. Not mib3. Someone might jump in.
The other issue is pkunzip can swallow some files when you unzip it. In this scenario use the built in unzip program in Windows 11. Open and drag out. I say this since I was told how to read the files for the yy.mm and pkunzip didnt show that file. I dont have mib3 but if pkunzip looses a file, that wouldn't be good.
Hi, do I understand correctly that I need to downgrade the map version to an older one and try again? But where can I get a version that will allow me to do this? MIB3 won't let me, unless I go through the service menu. Do you happen to have such a version?
I recall they did that downgrade on the map, then moved forward. Old map links you may find on this side of the board.
On 18.10.2026 at 17:42, Tell said:
Pamiętam, że najpierw obniżyli mapę, a potem poszli do przodu. Linki do starych map znajdziesz po tej stronie tablicy.
Today I plugged in a flash drive containing maps from 23.06 (if I recall correctly, I currently have 24.12 installed) I wonder if the MIB3 system will actually update to older maps? I didn't think that was possible. I’ll keep you posted on any progress; my commute to work takes 30 minutes, so I’ll give it a few days.
Yes you can jump releases. There is an information screen you can bring up that shows the current release. You are suppose to do that to check before and after.
