1.2 AZQ misfire after speedbump AGAIN !
A few weeks ago I went down a street with speed humps at about 15mpH
shortly after got misfire and this lasted a couple of minutes and righted itself. Engine management light was on for a while
Checking with VAG-COM got intermittent misfire on cylinder 2.
Changed ignition coil on cylinder 2 and ALL spark plugs. problem was gone and car running sweet.
200 miles later went down the SAME street and EXACTLY the same has happened again
Either the street is cursed or it is not the sparks or the 2 cylinder ignition coil
HELP !
do a compression test:)
1.2 3 cylinder engine, timing chains have been known to jump teeth!!
