superb 140 facelift
Was wondering if the power steering can be adjusted to have lighter assistance?
any help on this would be much appreciated...regards:)
It's very unlikely with the hydraulic set up on the B5.5. The assist weight is set by the torsion spring in the pinion/valve assembly inside the rack, which defines the steering wheel torque at which fluid is admitted to the rams.
What's wrong with the standard set up? I would judge the assist to be about right - it's not a Japanese grannie's shopping trolley. You should be glad you don't have the electrical setup fitted to later VAG designs - at least the hydraulics are reliable if you use the spcified fluid.
rotodiesel.
Not sure on the face lift, but I'm pretty sure i saw the option in VCDS,
have you checked that the tyre pressures are correct? as i would agree with roto, IMO the assistance is spot on.
thanks for the replies guys.........im thinking the tyres are getting a bit thin as wear indicators are below the thread.........do you think a harder compound tyre would be better?
I doubt it would make that much difference to the steering feel, the main thing with tyres and feel is pressure.
