Paging Cisco types- 871 router & DNS
I have an 871 in a very simple config here at home. For the moment, i want it to behave just like a random, cheapy home router, and then play with it's additional capabilities.
It's mostly working. In fact, it works nearly all the time.
The only issue I have is that I'm using it as a DNS proxy with some locally defined hosts i want it to resolve. All works for a time, and then, seemingly randomly it will refuse to resolve an external host that worked just fine a while ago.
By experimentation, I've found that logging into the CLI and pinging the host makes it work again- here's an example from nslookup on my PC:
C:\Documents and Settings\Chris>nslookup
Default Server:  farnsworth
Address:  192.168.1.1
> [url="http://www.piglet-net.net/"]www.piglet-net.net[/url]
Server:  farnsworth
*** No address (A) records available for [url="http://www.piglet-net.net/"]www.piglet-net.net[/url]
If I then log into the router:
farnsworth#ping [url="http://www.piglet-net.net/"]www.piglet-net.net[/url]
Translating "[url="http://www.piglet-net.net/"]www.piglet-net.net[/url]"...domain server (194.168.4.100) [OK]
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 62.233.104.60, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 32/41/64 ms
farnsworth#
and then retry nslookup:
Server:  farnsworth
Non-authoritative answer:
Address:  62.233.104.60
Am I doing something wrong? I'm speculating that once the TTL expires on a record, the router isn't going and looking at the external DNS, as this always seems to happen if I leave the router up.
A router reload also clears the problem.
Here's my config.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2009.02.22 18:42:19  =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 3797 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname farnsworth
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging message-counter syslog
logging buffered 4096
logging console critical
enable secret 5 [deleted]
enable password 7 [deleted[
aaa new-model
aaa authentication login local_auth local
aaa session-id common
dot11 syslog
dot11 ssid [deleted]
  authentication open
  authentication key-management wpa
  guest-mode
  wpa-psk ascii 7 [deleted]
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp excluded-address 192.168.0.200 192.168.0.254
ip dhcp pool pool1
  import all
  network 192.168.1.0 255.255.255.0
  domain-name piglet.local
  dns-server 192.168.1.1
  default-router 192.168.1.1
ip cef
no ip bootp server
ip domain name piglet.local
ip host [deleted].piglet-net.net 192.168.1.3
ip host farnsworth 192.168.1.1
ip name-server 194.168.4.100
ip name-server 194.168.8.100
ip ddns update method no-ip
HTTP
 add [url="http:///"]http://[/url][[email="deleted%[email protected]/nic/updatehostname="]deleted]@dynupdate.no-ip.com/nic/updatehostname=[/email][deleted]
 interval maximum 0 8 0 0
login block-for 60 attempts 5 within 60
no ipv6 cef
multilink bundle-name authenticated
username admin password 7 [deleted]
archive
log config
 hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
bridge irb
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip ddns update hostname [deleted]
ip address dhcp
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
snmp trap ip verify drop-rate
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encryption mode ciphers tkip
ssid [deleted]
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0  36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
--More--         !
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Dialer0
no ip address
no cdp enable
interface BVI1
ip address 192.168.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
no ip http server
no ip http secure-server
--More--         !
ip dns server
ip nat inside source list 101 interface FastEthernet4 overload
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
bridge 1 protocol dec
bridge 1 route ip
banner motd ^C Unauthorised access prohibited ^C
line con 0
login authentication local_auth
no modem enable
transport output telnet
line aux 0
line vty 0 3
transport input ssh
line vty 4
transport input none
scheduler max-task-time 5000
end
farnsworth#
Hmm. It does look like a timeout of some kind on the router. When the DNS doesn't resolve on the PC and you log into the router and ping from there, the first packet is dropped / doesn't get a response in time from the external Virgin/NTL DNS servers.
I guess it's just DNS that seems to drop off every now and then? Internet access is fine if you use IPs ?
Can't see much wrong with the config, but I'm no expert and have only done intranet stuff :o
Is there another machine you could have on your intranet that's not on a domain and can only be name referenced from the DNS service running on the Cisco box. See if you get similar issues which would then isolate whether an internet / ntl thing or just a Cisco thing.
Can't suggest much more than trial and error to get close to the cause :o
just a Cisco thing.
In the end, I reckon it turned out to be an IOS bug. I updated the IOS image, and it's working now. I was running a DNS server internally for a while as a workaround.
Ahh yes, the IOS bugs. Don't you just hate it when relatively simple protocol requirements just don't work!
