hiya guys ....
Just a genereal question at how many thousand miles should you get the cambelt changed , nearly done 50,000 miles now just wondered any help would be apreciated. amasny thsnks Jem xx
Im assuming it is the 1.6 if your talking about a belt.
Think it is 56000.
Would also get the water pump done too.
get the water pump to, it'll save the head going when the pump fails. witch it will.
Isn't the newer replacement pump a metal one and not plastic too so no risk of it breaking up?
Phil
ive got a 1.3 lxi felicia thanks jem xx
In that case I shouldn't worry about it!
The 1.3's are fitted with a small timing chain that will probably never break let alone at 50,000.
Although you may experience some rattling noises from it as you get a few more miles on it but will just rattle on for many many miles.
I changed mine anyway at 65,000 as it was annoying me.
Phil
Hi Jem
Basically what Phil says is right :D
Hope you enjoy the Felicia!!! I had a Felly 1.6 before my Fav
