rear wash nozzle
Should there be a nozzle on the estate rear wash, all I have is a very small hollow tube about a 1/4 inch long that looks part of the rear top stop light, when I use the washer it just trickles down the screen?????????????
Mine has a red bit that sticks out about 1cm from the rear light and points down.
Thanks for that, what size of Bailey caravan do you have and any problems towing it
We have the avondale dart 556 but tow it with the superb, I wonder if a 105 TDI estate would cope just as well
If it only trickles than you should check the waterline to the nozzle. It mostly comes off or breaks behind the left sidecover in the boot. If you will also find a bit of liquid swimming around down there.
Heard of this problem a couple of times in the german boards.
