Skoda Octavia Electric window problem weird one this
Have recently changed my drivers side electric window regulator ,motor the everything.
But when i open and close the window it takes 10 presses of the the button to close it in either direction.
The regulator was not a VAG issue but off EBAY for 50 quid , good quality just the issue of going up and down in steps.
Could this be a ECU with it's knickers in a twist or possibly a different Reseistance on the motor .
All that was on the motor was two wires Blue an Black so i have directly soldered straight to the control board where it supplyed the old motor.
I know change it again for a proper VAG one but ah well learn by mistakes.
Anyone got any sensible sugestions.
I don't follow you. Is the new motor regulator pretty much the same as the old one, but it came without a control box so you've swapped that from the old one by soldering the leads to the motor?
When the the window does move, does it seem to move freely?
Octavia I or II?
welcome along, please post in correct section for a faster response :thumbup:
Sorry guys Octavia 2
The window goes up and down freely but only in steps
The new one i fitted had the two leads comng from it which i soldered to the control box
The New one as made by MARRELI off Ebay.
contrrol box is still the original one just soldered to it
Welcome. Hope you get it sorted.
