Auto Windows Enable?
Well I reckon it'll work.
Hope so matey. :thumbup: Never underestimate my inabilities though.
My only concern is the ccm will be different on my classic spec, because of lack of folding mirrors etc etc .... but that's kinda the point of all of this, to find out, will report back when I figure it out.
Thanks for the info so far fellas.
  • Replies 68
  • Views 13.4k
  • allclownsareevi
    allclownsareevi
    Cable arrived this morning and success. Auto Windows now enabled. Thanks to other posters here for the info. As promised here it is, you lucky people, idiot proof guide to enabling auto windows.
Just to clarify, are we talking single button press total closure, or to enable the push and hold on the remote?
Push and hold.
I await your report mate as i will have a go tomorrow if successful.
Push and hold.
OK, I''ll ignore then as the Octy does this already. If we were talking TC, then I'd have been interested.
Ok I'm slightly more optimistic today, connected vag-com and verified the version of the CCM and it's one of the ones listed .... so as soon as my serial cable shows up I'm trying it.
Incidentally I reckon this can be done via VAG-COM ..... but so far I can't confirm this. I'm reluctant to try VAG-COM because right now it's only a theory. I'm going to try the method mentioned earlier in this thread first ..... BUT after that I'll try vag-com and post that too.
everywhere i have read including seat forums, it states this isnt possible via VAG COM
Don't forget to make a note of the original values before you change anything.
where did you get vdc pro from as the site stated early has dead links?
Have a look at post #97
Thanks dude, downloaded and will have a play tomorrow. Need to sort out DOS now! :rofl:
Lol, your PC already has DOS ;)
not XP, it only has a command shell:eek:
Lets not get all IT now, get it all day mate...
Any luck dude?
Any luck dude?
As soon as my serial cable shows I'll let you know man, right now have a usb cable and not about to try experimental vag-com just yet until I'm reasonably certain I can reset values with vds pro.
There is a function in vag-com to recode the ccm though so perhaps it can be done with that. Want to use the tried and tested method first though.
OK mate, i have got my vagcom license through and within 15min had the laptop plugged into the car and had the following sorted:
ANTI HIJACK
46 – Central convenience
10 - Adaptation
Channel 03 Auto Lock (auto locks car after 10mph)
Channel 04 Auto Unlock (unlock the car when u take the key out)
SINGLE DOOR UNLOCK
46 – Cent Convenience
07 - Recode
The single door unlock give an even number i.e 00064. To make all the doors unlock with one press, just add 1 i.e. 00065
All thanks to roo's guide
Had the added bonus that the car locks itself if key removed for over 30sec
Sounds promising.
Did it sort out the folding mirrors also?
Tempted to buy a cable and have a play...
How much did the vag-com licence set you back?
Matthew
Sounds promising.
Matthew
Dont wanna nick the thread here as Im interested in the total enclosure which requires vcd pro.
However: license cost £68 and i got it in 1 working day. Ive been using the shareware for faults for over 3 years. At least this why you get the full error codes. Worth the investment. I have probarly made my money back within 5min!
Folding mirrors require the autoflex module i believe. My comfort doesnt have folding mirrors. I know this as i enquired about this for my Cupra.
I swear I'm going to post back here with results .... just as soon as my serial cable arrives. :rofl:
i await your response mate.... where is the ccm info captured on vagcom? I have a licensed version at last! Hope to play around over the weekend as the wife is going to her cousins. It will be my lappy and car all weekend:rofl:
>>> Click For Video Demo <<<
This is going to be extensive only because it's step-by-step - so settle in. :thumbup:
You're going to need.
A Superb
An old laptop, something from biblical times with a serial port on it
A serial cable
An old DOS program called VDS Pro, check this link on another forum, I seem to recall they had some info on that.
Passat World Forums - View Single Post - Window rollup/rolldown audi style without autowindow/alientech/volkswindow
an audience
some provisions
.... and a little courage
Got all of those?
Excellent!
On with the show.
1. Connect your serial cable to the laptop and plug the other end into the port under your steering column. Keys in, turn ignition on so dash lights come on. Engine needn't be running.
2. Boot up the laptop into a dos environment (you can use a Win98 floppy disc/CD-Rom). Start VDS Pro (use the vag.bat file to launch the program), you'll be hit by this screen.
3. Setup VDS to use com port 1 at a fixed baud rate of 9600. Do this by hitting alt+f to bring the configuration menu down, then press alt+c for connextion menu. Should look like this. Configure as shown and select "ok"
You'll be booted back to the screen in step 2, hopefully all will be well and your laptop and car will be communicating well. If not, I can only suggest trying different com ports in the connection menu, however these settings seem to work best with nearly all models.
4. Type 46 to connect to central convenience module (CCM). You should be presented with a new screen like below. Your CCM module number is listed on the bottom left hand side of the screen in grey. Check that number against the tables further down this post. If your CCM number is listed you'll find your memory addresses / original values / new values. Only continue if your CCM is listed below.
5. Type 11, to begin login procedure. Login with the number 19283
6. Read the current values by typing 26 and entering your corresponding memory address for your particular ccm - again see tables below.
Upon entering the memory address this comes up ... or something similar. Make a note of the original values!. Repeat this step for all memory addresses listed for your CCM.
7. Ok so it's time to write new values. Type 27. You'll be asked for a memory address and a value. Again refer to the tables below and double check your figures. Don't just copy the screenshot below!
After entering each new value you get a confirmation screen like this. Select ok to exit the confirmation prompt. Repeat this step for each memory address listed for your CCM in the tables below.
8. Once you've done each value, you can disconnect by typing 06 in the CCM menu to get back to the main menu. Then close VDS Pro down altogether. Now unplug everything, exit your car and lock it. When you now open your car with the keyfob and hold the button the windows should start to roll down and stop when you lift your finger. The opposite applies when locking.
The tables:
The following codes have been collected on different boards in Germany for the listed modules.
I personally found my CCM on an 53 plate Superb classic to be CCM number 1C0 959 799 B. I used the Limousine/Sedan values and all worked fine.
1J0 959 799 AH (any index) and 1J0 959 799 S 03B
Memory Address / old value / new value
04283 / 8 / 2
04289 / 8 / 2
08628 / 242 / 246 driver side front window
12724 / 250 / 254 passenger side front window
16820 / 250 / 254 driver side rear window
20916 / 242 / 246 passenger side rear window
1J0 959 799 J 00E
04286 / 8 / 2
04291 / 8 / 2
04296 / 8 / 2
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Variant/Wagon
04361 / 75 / 67
04362 / 75 / 67
04363 / 75 / 67
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Limousine/Sedan
04361 / 74 / 66
04362 / 74 / 66
04363 / 74 / 66
So there it is. Longwinded I know but was going for a comprehensive step-by-step approach. Read through it carefully. My advice is if you're still not confident leave it alone. Screwing with the car's settings can ruin it and leave you with nothing more than a huge paperweight.
Be careful to make sure your CCM module is listed above. Incidentally someone asked how you can get the CCM module number from VAG-COM.
Start vag-com
Enter "comfort/conv" tab at the top, and select 46 "Central Conv."
CCM number is listed as VAG Number, top left:
Good luck :thumbup:
Edited by allclownsareevi
Excellent write up :thumbup: Should be made a sticky.
Told you it would work :D
That you did sir, that you did. Can't have the Audi owners lording it up over us can we ... hence the title on the video link page. :rolleyes:
I wonder how many more Superb owners are going to have a go at it now?
Judging by the replies ....... 0 :rofl:
