4 question i need helllllllp?!?!
hello all i could use a hand with these questions?!
1. i have a fabia 1.2 3 cylinder that i have purchased cat c. i have a standard key no remote locking, is there a cost effect way to get the flip key and remote locking working?
2. i want a vrs handbrake cover, but have no idea how to swap them any help?
3. also want a vrs rear back box will that fit on?
4. and an induction kit for a 1.2 3 cylinders? available?
any help would be great thanks:confused:
?koda Accessories is the central locking kit
?koda Accessories is the plip to go with the central locking.
The handbrake could be complicated - thread here about it.
I have no idea on the exhaust, but I would imagine the vRS one is quite a bit bigger, so it would need to be bodged on.
Induction kits are available for pretty much every car, I'd contact someone like Awesome or JabbaSport for a quote.
vRS backbox will need a vRS style bumper with the exhaust cutout section. A stock bumper will cause the tailpipe to stick out very oddly unless some modification was done when joined up.
For the RCL - Are you saying you have just a key - It is not already using a flip-key? If it is a normal key then you will need to retrofit a kit such as that above. If however you have a flip-key but have to use the door barrels to open the car, then it's a relatively simple exercise to activate RCL using vagcom
To my knowledge, the handbrake covers are all the same black plastic affairs.
For best, safe, induction noise, best off to fit a performance panel filter such as one from Green.
sorry forget to mention i have a vrs bumper set, but will it fit straight on them?
and can you give me a link to a panel one if you could?
