Removing side strips
Just wondering whether the black plastic door strips on the Felicia are held on with glue or whether there's small holes behind them, as I'm thinking of removing them. Took the small strip off the wing earlier and it just has glue behind, just wanted to check what's behind the bigger strips on the door before removing them :confused:
I believe you use a heat gun carefully to remove them.
