brakes r32 and cupra
hi, a friend of mine here in greece with an octavia ii rs, wants to upgrade his brakes with r32 brakes. Someone told him that are same with seat cupra brakes which are cheaper here.
does anyone know if this is true????
2004 on cupra, S3, and r32 have same brake system AFAIK
what does it means AFAIK???
AFAIK means: as far as I know.
The Cupra uses the same front brakes but different rear brakes. If you are just going to change the fronts then the Cupra brakes will be OK, they fit straight on :)
