Warning light just came on! No Manual, HELP!!!
Hi all
I am hoping someone can help me with my dilemma. All of a sudden a warning light has lit up on the speedo clock which obviously means something is wrong! But unfortunately my car did not come with an owners manual or service record (I bought the car from a large "supermarket type" garage in Darlaston, Birmingham).
Any way here is the dashboard before starting!
And here it is after starting the engine!
The car is a 52 plate and is the Octavia Elegance 2.0l 16v version.
Please help if you can. Many thanks, Paul
that is the engine management light... ecu
will need a diagnostics check done to see what problem is.
Darlaston is a good way from Birmingham :)
Have a look at this thread.
Hi and thanks for your replies! Brake lights are working! Darlaston is only a few miles from B/ham as it's just by Wednesbury from J9 of the M6!!;)
Kind regards
Paul
Kind regards
Paul
Check my Location Paul :thumbup:, and don't confuse the Darlo lot with Brummies, they'll lynch you :)
Sorry about that cjb! Now I understand :thumbup:
Kind regards
Paul
Ok, it's not the brake light switch then (common issue). VCDS job then; have a look at the VAGCom forum for someone near you who'll do it for a few beer tokens.
Kind regards
Paul
Only Joking!. Where are you?
Hi cjb I am in sunny Great Barr :cool:
Hi DGW many thanks for the link mate :thumbup:
Thanks for all your help guys. I had my car booked in this afternoon at Kings Heath (Where I believe ironically it was first registered!) and the strangest thing happened! the warning light went out on it's own accord :holmes: can you believe that. So I didn't need to go in the end! I will be keeping an eye out for it in future though.
Kind regards
Paul
Just up the road then. I pass through Great Barr every day, heading for the joy that is J7.
If you need the car scanning drop me a PM.
let just hope the bulb in the warning light hasnt failed aswell fingers crossed
Hi cjb
Thanks for the kind offer mate. As of yet the car does seem to be working perfectly well again so I will put it down to a "glitch!". I will PM you if I need to get the car scanned though in the future mate.
Cheers, Paul
  • 2 months later...
Hi ihad that problem with my octavia 1.6 it was the sensor for the cooling fan ,,i fixed that then a few months later it came back on and it was the termostat sensor so check the cooling is ok
