amp power
i have managed to get the standard stereo out using a hack saw blade cut in half , changed the red and yellow wires over so that it turned off when the key is removed(both these thanks to forum members) ......
managed to get my RCA leads passed through from the back of the stereo, the same with the remote...
then my plan came to an end...i cant find anyway to get the amp power lead from the boot to the battery.....
please help as im sat in the car now on the laptop.....only got the car today and have already fitted a cupra R splitter and this is really annoying.
Pull up the carpet, should be a hole you can use in the bulkhead :)
go under the car and cable tie it to the exhaust.
HTH.
HTH.
:rofl: you should change your location mate, you ain't on this planet!
passenger front carpet ? thanks for quick reply ..... have you personally done this yourself ?
what exactly are you trying to say here?
Yup :)
Not done one on that particular car, but have an plenty of others!
big help mikeSM56 .....MODERATOR might as well close thread now...
Click on thread tools above your first post, You should be able to lock it yourself!
nothing about locking in thread tools, the guide is very handy, when the search is used nothing really comes up to help with amp wiring etc?
Guest
