Chrome interior door handle and vrs grey trim
Does anyone know where I can get an interior chrome door handle as the chrome coating is coming off one of mine. And what are they like to fit?
I also want to know where i can get the grey plastic trim which fits around the stereo/climate etc on a Vrs. Is their anywhere you can get them in the UK without having to pay ridiculous shipping charges? Thanks
You can either get them from a dealer or a scrappy, you need a tork screwdriver and a small flat one to remove the mesh screen.
Removal, remove the mesh screen then the screw, then poke your finger into the hole and slacken the first 2 clips then gently pull, turn the handle over and you will see the same system that is used on a push bike just ease the pressure slightly and slip the cable out refitting is the same as removal but slide the thin end in first then gently push the housing home so it clips in, time for the job 2 Min's
what is the mesh screen?
