Turbo and fuel
I have a 2001 octavia tdi, it seems to sound as though the turbo has a permanent whistle all of a sudden, especially on tick over and there used to be a shut off noise that came on when the car switched off, that has stopped.
It also seems to be a bit heavier on the fuel.
Could this be a connected problem?
sounds like the antishudder valve may be sticking because of a lot of crud in the EGR valve which may also means that the EGR itself is sticking and losing some performance/mpg it could also stick shut just as easily which means next time no start, I would look there first :)
it may be the dreaded vnt turbo vanes sticking causing the whistling and high fuel consumption
Can i sort this out myself and if so were is the EGR valve on the car?
Thanks.
Hi dont know if this helps but I was told by the mechanic years ago that the type of turbo on the octavia does have a natural whistle on it mine had it and the superb has it to but on giving it whellie not on tick over :confused:
