Bolero Radio- RDS Set Up Question
I’m getting a lot of traffic warnings from radio stations that are a long way off ,as I traverse the Midlands. Getting fed up with pressing the Cancel button for irrelevant information. I note that the Bolero has the option of an ‘Automatic’ or a ‘Fixed’ setting for RDS. If I switch to ‘Fixed’ , what would it be fixed on? No info in manuals.
As found on page 14 of the online Bolero pdf manual:-
Switching the RDS function on or off (RDS regional)
– Press on the function key [RDS Regional] and select a set-up in the
opening pop-up window.
– Press on the function key [automatic], doing so will always choose the
frequency for the radio station heard, which offers the best reception
at the present time.
– When pressing on the function key [fix], the unit attempts to hold a
radio station emitting regionally long enough until the reception
quality is so bad, that there is a risk of a program loss.
Hope that helps.................
Thanks for finding that. I think the 'fix' setting is the one I need to listen to stations 'emitting locally' in North Derbyshire rather than Radios Stoke, York, Humberside , Leicester, Nottingham etc. I hope that if the 'fix' setting loses reception it will switch to another 'emitter'?
Here's the link so you can download a few manuals as they may be slightly newer than the ones that came with the car. There's also a sticky link in the Octavia 2 section.
?koda Auto - Documentation - Octavia - since 06/2009
Are you going to the Mansfield meet next Tuesday?
