RS Cruise control upgrade
Hi
i have a 51plate 2002 spec RS octavia. I was told to replace the stalk as the ecu has the the stuff in it ready to work, will it do the job?
Edited by speedyjon
I think you need a loom and you will need it coded into the ecu.
HTH
Im sure i've seen one of the sponsors here do an upgrade kit for about £185
Or PM VRStu
Hi,
Unit18 also do them. think about £180 all in.
The prices being quoted are stupidly high, I bought geniune VW cruise stalks and required wiring for less than £75. Fitting was easy, it simply plugged in on the new stalk and I had to add the pins in at the ECU end.
Stupidly high if you can do it yourself, but what if you can't, then you have too pay someone who will charge you for doing it. That person/s will charge for their time. It's not exactly a two minute job is it.
Dean225 makes it sound simpler than it is. I don't see it as a difficult job myself, but here is a quick rundown of what's involved
Remove airbag
Remove steering wheel
Remove steering trim
Remove slip ring
Remove old stalk
Fit new stalk and route additional cable.
Remove lower dash panels.
Release relay boards and fusebox
Remove windscreen wiper arms
Remove plenum cover
Remove windscreen wiper assembly
Next items depends what loom(s) you have.
Release connector so it is accessible from under dash. Connect stalk loom to connector and fuse holder in fusebox.
Connect loom into ECU plug.
Refit everything.
Enable cruise using VCDS/VAS
You need a 12mm Spline bit for the steering wheel bolt.
you can get the kit for 65 quid
Edited by ap0gee
Unauthorised commercial activity
Remove airbag
Remove slip ring
Remove old stalk
Remove plenum cover
Refit everything.
Pah easy !!!!!
Like I say, not everyone would want too attempt that would they :)
