Increasing tickover RPM on Fabia VRS?
Hey guys, does anyone here have the ability to increase the engine idle RPM on a Fabia VRS using VAG-COM? Cheers and how much will it cost nd where you located? :-) cheers guys.
Edited by Gez
Please correct me if I'm wrong, but isn't this pointless and a little risky?
The power drops off at the top, so more revs surely will give even less power?
Have you had a remap? I thought that when mapping the rev limit could be moved?
Buy a petrol if you want revs.
Diesels shouldnt be revved hard, hense all the low down power.
Big sorry to you guys! my mistake i shulda put "Idle Revs" lmao, im looking to increase the idle rpm lol. Thanks for the replies none the less lol.
(original post now edited to say idle rpm) lol
I don't think it can be adjusted. Why do you want to?
I want mine set to 1100 so the SMF doesn't vibrate & rattle the car to bits. :) Going to be asking for that to be done when my next mapping session takes place. I'm going to be asking for a lot.... :rolleyes:
I've added "tickover" into the thread title to prevent any more confusion :D
i know you can increase "tickover" speed on the vas 5051b which we use at work but not sure about vagcom i would think it possible if you can get the correct info from rosstech
Ah rite thanks for all the replies guys, it doesnt need to be vag-com, just put that as i thort its the only thing u can adjust stuff on the car wtih :-s Sherlock how much would you charge to increase the engine tickover on a Fabia VRS? cheers :-)
Pikey mod? Ever so slightly move the accelerators resting position? Cable ties, is there anthing you cant use them for?:D
I can do this/ have done this on mine when I had a dogbone mount in
  • 2 years later...
You can do it on channel 2.
But it will only increase it a small amount.
I had it done by AKS Tuning :)
