Headlight washers stopped working
I noticed this evening they aren't working. Must be a power fault somewhere as you can't hear the extra click for the relay either. Everything was frozen up so i gather it's related? It's thawed out now and still won't work. Any ideas? Is there a fuse for them? The windscreen washers work ok :S
When you wash, do you hear/see washer fluid running out anywhere as a hose may have popped off.
I don't think they are powered at the nozzle but extend under fluid pressure. The power is at the bottle
Edited by darrenw
I found a 20 amp fuse blown for them. I didn't replace it yet as i'd say it was due to the water freezing and then powering it up. The motor probably froze solid hence the fuse blowing, when it thaws i'll change the fuse and fingers crossed no damage done.
