VRS Estate WET FLOOR
Hi has anyone had problems with water coming up through the floor ?
I lifted the carpet in passenger footwell & sealed around cracked looking rubber bung but have now noticed the carpet in rear passenger footwell is wet
Any help gratefully received.
There are some drain holes under the hood/bonnet that get full of dirt and does not alow the water to drain. This cause the water rise to a level were get in the car thoug the polen filter base. This is a fault with Passats, Audi A4 & A3, Skodas and Seats. All part of the Volkswagen Audi Group.
If you make a search you will find many forums that talk about this problem.
Make a search on gogle for VW WET CARPETS, AUDI WET CARPETS, SEAT WET CARPETS
Also here is a DYI with pics for the VW Passat with the same problemo
VW Pasat Wet Carpet
Good luck,
Isaac
Edited by Turbo_Boss
Do the rear washers work ok?
The rear washer is working ok, the pipe came off a while ago but I fixed this.
Thanks Isaac, I'll look into this !
