Felicia Radio to switch off on ignition?
Done a quick google on this but just brings up dross...........
The other half has a felicia with a "Skoda Audio 210" in it, and other night i had to go out and change battery on it, turns out she had left the radio on..........since she has had the car, its permanently wired to live. so has to be switched off on unit, but sometimes it comes back on like other night when she has got out the car.
Has anyone got a scanned page of the wiring diagram please so i can try and stop it doing this by putting it on a switched live feed or ive been told that there is a setting to turn it off on the ignition in the radio settings, but i havent got a hand book for it and i cant find any settings, only one i can think of it being under is the "EXPERT" which i need a code for and guess what, i dont know it!!!
Or know how to do it. Help please before she does it again and i have to freeze whilst sorting it out!!!! :'(
Nath
i've got a aftermarket stereo, and i've had similar problem knowing it been turned off, so now i just remove the stereo fascia, obviouly wont turn on without the fascia
It's due to the way the stereo loom is wired (same on all felicias and favorits). If you want you can join a wire with the switched live one, and the easiest way with most stereos is to use a bullet connector and connect it where the stereo allows you to swap the wires over.
Edited by anewman
Fixed it the alternative way, took it out and fitted an after market one with removable fascia, ive done my bit, she just needs to remember to take it off now!!! :giggle:
Thanks for the replies
Edited by nathan_marriott
