Fault code-P0601
Engine check light does not work on my VRS, so check it occasionally check it with a very basic code reader and code P0601 has come up can't find anything to tell me what it means, anyone got idea's?
16985 - Internal Control Module: Memory Check Sum Error. P0601
Cheers for that Westallc. Got search button too work, seems if i go too Skoda stealers i'll need a new ECU, or if a go to a VAG specialist i need an ECU re-flash.
whatever way you look at it doesnt soung good :S
look on the bright side it still drives unlike mine :'(
Don't worry about it.
I had the same code last july and i can clear mine for a few days then it comes back.
I do know one tuner that can clear it for 1 hours labour.
Not to worried after searching around, seems to be a problem on standard or mapped cars luckily not a common fault though, there was an update from Skoda a few years back. The larger mapping companies also had a cure if the fault appeared on mapped cars, was just a case of tweeking a couple of the parameters on the software. Had a trial APR map 2 years ago so have to take a trip back to the tuners and see what they can do.
