Felicia not starting
Hey guys got a 96 felicia glxi 1.3 always had trouble starting where the car would start fine then just die would probably do this 3 or 4 times then start and run fine
but lalely the car has not been starting at all i turn the key and nothing happens leave the car for an hour or so and it usually starts fine
breakdown guy checked with a meter thingy said that current was getting through to everywhere so didnt know what to make of it
any body got any ideas...
normally coolant temp sensor change will fix it, but it's hard to say without looking
that has already been done about 2 months ago
Similar problem here but related to wet weather. If car is left out in wet weather overnight it's difficult to start. If left our for a couple of days it won't start.
When, eventually, it starts there's a huge amount of white exhaust "smoke": this is water vapour so the engine is suffering from extreme condensation.
No problem in warm weather or in wet weather once warmed up.
Trouble is the battery gets low so needs to be charged. Just had to do this and second problem - the radio is bust! It's coming on in SAFE mode & we don't have the key - this is a replacement radio from Skoda because they had the same problem: they killed the radio at a service and discovered that it's impossible to find the key code to get it going again. Internet sites no help at all, they all advertise it can be fixed but when you actually get to the nitty gritty they admit it can't.
ignition coil?
if it starts and runs fine for a couple of seconds then dies it sounds like an immobiliser problem to me, have you tried using a spare key?
Seconded.
I had a similar problem with a Scenic, so did my wifes cousin. Both cars were sorted by cleaning the TDC sensor. I imagine the Felicia has one too?
the not starting was solved with a new starter motor managed to pick one up for £20 from the scrappy i think the solenoid has gone on the old one
still have the occasional start then die issue though how would i know for sure if it was the immobiliser
Does it start, run for a half second (perfectly well) then die completely? That's how the immobiliser will work.
If it doesn't do it straight away, then I don't think it's the immobiliser, as (from my tests messing about with them) it only works when you initially start the car; after that you can disconnect it or put another key near it or take it away (I've tried all these, I was bored), and it doesn't make any odds.
yep thats exacty what happens will do it about 3 - 4 times then starts and runs perfectly
Sounds like an immobiliser issue. Maybe the signal is a bit weak? could be the ring round the ignition is the problem, or, of course it could just be screwed.... might be worth trying taking the little glass immobiliser bead out of the key and trying it right next to the immo ring.
yeah, if you change the immo ring around the ignition switch you wont need to do any coding or anything like that, i will be jut plug and play,
