speedo sensor
how do you change the speedo sensor on superb 1.9 tdi 03 thanks
If you mean the ones that pickup from the front wheels, it simply prises out of the brake disc shield and unclips from the loom near the arch liner in much the same way the brake pad warning one does.
That's the ABS sensor not the speedo sensor.
The speedo sensor is on the gearbox adjacent to the driveshaft - LHS I think.
rotodiesel.
rotodiesel.
but is it easy to fit and how to do it. thanks dave
It is a little difficult to get at, but it's a straight swap.
HOWEVER...
Before you go buy a replacement sensor, I suggest you attach a drill to the existing sensor to see if it works. I've seen a good number of cases where the sensor is OK but the cog in the box has split.
Edited by rwbaldwin
