How to: Change Front Speakers Fabia VRS
Ok so I've not had a good luck at the door card yet but was wondering if changing the front speakers is a simple job or full removal of the door cards? I have done a search but can't find the answer.... Help!!
Alan
Has no one done this? Are there any screws or just poppers? fancied knowing before I started yanking the door cards off.
Alan
Search is your friend :) Look for a thread started by tfboy. He done a step by step guide.
Thanks. Any idea of the title of the thread? Was having a mare searching the other day? Thanks for pointing me in the right direction.
Found it Thanks!! :smirk:
  • 5 months later...
I have same problem... but cant find the answer or thread..???
You need to remove the door cards to change the speakers, also you will need to drill the rivets to take the old speakers out. Mounting depth is a real issue so choose the replacements carefully.
