Drop Link Replacement
Nice easy one this is
Undo wheel bolts
Jack car up and put axle stand under to support car
Remove wheel and spray WD40 on the DL bolts and go have a ciggy
Use trolley jack on the bottom nut of the suspension, the most groundward nut you can see
Jack the trolley jack to bring the drop link level
Using the two spanner method, loosen both bolts
Pull the bolts out and the DL will fall away
Put new link up to the top hole and push bolt back in
Same with the bottom and put nuts back on bolts and tighten fully
Wheel back on and drop the car.
Edited by Supurbia
