SAI pipe
Since the weather was decent today i thought id make a start on trying to solve the dreaded "17705" error code
so i take of the split pipe after the "Y" piece and go about taking off the piece under the manifold. (The pipes internally are very clogged!)
after i put it back together with new piping, i noticed the pipe that goes from the what i think is the SAI to the back of the engine near the Puck/DV is cracked. This was confirmed when i felt air coming out of it when starting my car from cold.
Its the pipe that is held down by 2 bolts are the front of the manifold and then goes to here http://farm3.static.flickr.com/2727/4021535650_773b9432e3_o.jpg
Anyone know the part number for this pipe? is it worth changing or should i just leave it?
Also snapped dipstick tube :( ...anyone got the Part number for this + cost?
thanks in advance
Replacing the split pipe has made a massive difference already :) once I get this little niggles sorted out i will be fitting a Catch tank
Its shocking the amount of Mayo/crud in these pipes!
Edited by vRShafz
Did you buy the replacement pipes from the dealer as im looking to do this myself next week. Can you give me an idea of cost?
cheers
cheers
no mate im going to be fitting my own Catch tank so im using some oil resistant hoses along with T/straight pieces http://www.pimpmyskoda.co.uk/V2Images/ModsEngine/OilCatchCan.htm
i just replaced the perished pipe for now while the group buy is sorted on the 19mm inlet/outlet catch tanks
http://briskoda.net/forums/topic/151653-oil-catch-can/
Hmm that pic looks familiar :p :thumbup:
haha yeah, top site mate, helps me alot and gives me confidence to work on my own car
Can I just replace this pipe with a normal silicon hose?
