Octavia II, MFD3 and Subwoofer Wiring
OK, considering a "boot build" for a 10" sub with Vibe mono amp. Not sure which is the best way to run it - line from MFD or disconnect the rear speakers and use the high level inputs on the amp. Question - are the line outs from the MFD fixed or variable output. I don't really want or need to introduce an additional amp for the fronts as I think the on-board one is probably good enough but I don't want to be mucking around with levels all the time for the sub.
Interesting question. I believe the ones at the bottom right of the main quadlock connector are variable and I assume that the ones in the smaller connector under the fan are fixed volume for connecting to external monitors where you'd want to use headphones.
Actually, I'm doubting myself now. Hopefully somebody can give you a more definitive answer. Shark 90?
Edited by wardth
As far as I understood you will need a high-low adapter (helix is a name that is often mentioned in our boards) to connect an amp to the columbus. It doesnt have a line out for an amp.
Er, it does - the question is if they are fixed or variable! I wouldn't need a high - low as almost all amps have high level inputs anyway.
Come on guys SOMEBODY on here must know!
BUMP
Where do you see a connection for an amp? You will need an adapter. (Helix Hi-Low)
There is no line out on a Columbus/RNS510. All you can do is take the speaker outputs and change them in a signal for an amp.
Oh this is *******s - has ANYBODY done this? I've had several people say that the MFD3 has line outs and now I'm not so sure after Magic62's picture!!!
It really doesn't matter to be honest because I think the easiest route is to just break into the rear door speaker feeds and shove them into the high level input on the amp. I would imagine the cables run along the sill tray I just have to figure out which one is which! I don't see why I would need a high / low adaptor in that case unless I'm missing something?!!!
Edited by wardth
Most of the users on the german board use the Helix Hi-Low adapter. Think it is mainly because of the sound quality. Should be better with a low amp input.
Just read some of the posts in the german board. All the members who added a subwoofer to the columbus did it with: Helix adapter, amp, sub.
On the RCD510, it's the (unlabled) pins 2 (right +ve), 3 (earth)and 8 (left +ve) on section C of your diagram. Are they definitely not connected on an RNS510?
This is what I found from a RCD510:
http://www.mytouran....ml/rcd_510.html
All the current headunits from the VAG group are connected to their amps by CanBus, so they wont need an amp output.
(this is also why many wrongly coded units dont work with the original speakers).
Edited by magic62
From my-gti.com...
1. Aerial Connector
DAB aerial input connection, optional
or
SDARS aerial input connection for vehicles for USA and Canada
2. Multi-pin connector 1, 8-pin, for loudspeaker outputs
1 – Rear right loudspeaker, positive
2 – Front right loudspeaker, positive
3 – Front left loudspeaker, positive
4 – Rear left loudspeaker, positive
5 – Rear right loudspeaker, negative
6 – Front right loudspeaker, negative
7 – Front left loudspeaker, negative
8 – Rear left loudspeaker, negative
3. Multi-pin connector 2, 8-pin, for voltage supply lines and CAN bus
9 – CAN bus, high
10 – CAN bus, low
11 – Display voltage supply, positive
12 – Voltage supply, negative, terminal 31
13 – Display HV CAN bus low
14 – Display HV CAN bus high
15 – Voltage supply, positive, terminal 30
16 – Anti-theft coding control signal, SAFE, positive
4. Multi-pin connector 3, 12-pin, for telephone and microphone signals
1 – Microphone input, negative
2 – AUX output, audio, right
3 – AUX output, common signal earth
4 – Microphone output, negative
5 – Telephone audio input signal left, negative
6 – Telephone audio input signal right, negative
7 – Microphone input, positive
8 – AUX output, audio, left
9 – Microphone output, positive
10 – Telephone mute (mute switch for radio)
11 – Telephone audio input signal left, positive
12 – Telephone audio input signal right, positive
5. Multi-pin connector 4, 12-pin, for CD changer control and CD audio input signals
1 – AUX signal input, left
2 – AUX signal earth
3 – CD changer, audio signal earth
4 – CD changer, voltage supply, positive, terminal 30, contact continuous load greater than 1 A, temporary peak load 5 A
5 – Not assigned
6 – CD changer, DATA OUT
7 – AUX signal input, right
8 – CD changer, left audio channel, CD/L
9 – CD changer, right audio channel, CD/R
10 – CD changer, control line, switched positive
11 – CD changer, DATA IN
12 – CD changer, CLOCK (internal check protocol for data flow monitoring)
6. Multi-pin connector 5, audio and video, 26-pin
1 – Reserved for Debug RX protocol
2 – Reserved for Debug TX protocol
3 – Not assigned
4 – Video signal input, RGBS, negative (ground)
5 – Video signal output LF, Right (Audio use 17 for ground)
6 – Ground Sync input
(Internal universal preparation for mobile telephone, mobile telephone detection)
7 – Video signal output, vertical and horizontal synchronisation
(Internal universal preparation for mobile telephone, cradle and button evaluation)
8 – Video signal ouput, green
(Internal universal preparation for mobile telephone, cradle, aerial diagnosis)
9 – Video signal input, RGBS, negative (ground)
10 – Video signal input LF, right (Audio use 24 for ground)
11 – Video signal input, screening earth
12 – Video signal input, vertical and horizontal synchronisation
13 – Video signal input, green
14 – Not assigned
15 – Not assigned
16 – Not assigned
17 - Video signal output, LF, negative (ground)
18 – Video signal output LF, Left (Audio use 17 for ground)
19 – Video signal output, RGBS, negative (ground)
(Internal universal preparation for mobile telephone, cradle, negative)
20 – Video signal output, Blue
(Internal universal preparation for mobile telephone, switched terminal 30)
21 – Video signal output, Red
22 – Video signal input, LF, negative
23 – Video signal input, LF, left (Audio use 24 for ground)
24 – Video signal input, RGBS, negative (ground)
25 – Video signal input, blue
26 – Video signal input, red
7. Aerial Connector
AM/FM aerial input connection
8. Aerial Connector
FM 2 aerial input connection
Edited by wega3k
There might be a difference between the US/Canada version and the european version.
  • 2 months later...
I see this is a few months old, but I want to throw my opinion in.
On the 26-pin plug, I thought pin 5 and 18 was audio out. Use pin 24 as ground. Wether it is variable or not, well...
  • 1 year later...
Old subject i know but is Multi pin connector 2 - pin 11 would this be know as ignition live or permanent live?? I need ignition live to connect to a helix block line converter to run an AMP??
Anyone ??
