Vagcom
Does anyone in Aberdeenshire have a VAGCOM/VCDS and is willing/able to help me activate my DRL?
Should they not already be active? Its like having wipers that need activating. Odd. :dull:
Do you have a FL VRS? If so, then I would have expected them to be active. Would it be a case of using the indicator arm to switch them on? I saw something about that in a thread somewhere along the lines of pulling it towards you, then either up or down for turning them on/off.
(Might be in the manual?)
If you need VCDS, I'm sure we can arrange something.
Edited by jrp
If you have maxidot, check the setting there, if not:
Switching on daylight driving lights
– Switch on the ignition without turning the light switch out of the position
0.
Deactivate function daylight driving lights
– Pull the turn signal light lever towards the steering wheel up to 3
seconds after switching on the ignition and at the same time, slide it to
the bottom and hold it in this position for at least 3 seconds.
Activate function daylight driving lights
the top and hold it in this position for at least 3 seconds.
jrp have just followed your instructions and it worked a treat thank you .
Edited by Pedd
MIght have to get my vRS to garage. just cannot get DRL led's to activate. not in maxidot and stalk method not working either :'(
  • 8 months later...
0.
Spot on! Cheers!!
