what is the purpose of this pipe?
Changed my breather y pipe coming out the top of the engine and ended up snapping a plastic pipe, what is the pipe for? if you follow the breather pipe leaving the top of the engine it splits with one end going towards the turbo (Left) and one going down towards the secondary air pump (right) its the the first pipe you hit going right that I snapped the top off.
Any ideas peeps?
Any ideas peeps?
I am thinking its part of the vacum system that runs down to the crankcase ventilation?
part number or name anyone?
yep it part of the crankcase venting system needs to be rplaced asap very common 2 other ways to fix it instal catch tank or awesome do a silcone hose to replace it with.
it goes into your intake so with it broken car will run a bit dodgy get it replaced asap
p.s cheaper to buy an uprated one than a standard part fromt he stealers
