would this fit
Yes .....
Moved to octy 1 :D
"Adds up to 7 to 13 additional horsepower and up to 16 foot pounds of torque ! ( result might be vary )"
:rofl:
Toyosport? Is it my imagination or do they make the ebay intercooler kits?
Edited by chicken_eyebrow
Yep that'll fit just fine! Not sure about their claimed power figures though!!
I've looked at these a few times on ebay, very temtped.....Does anyone have one of these fitted to their vRS?
Is there a reason why the are so cheap?
:think:
It's a metal pipe and a (very) cheap and cheerful cone filter.
They're certainly cheaper than the likes of a Carbonio but worth swapping the cone filter on the end for a better one.
the reason they are so cheap is because the owner is never there and the staff are pocketing the money . hint hint :D
hi there, i have also purchased one of these and intend to change filter for a better one, just wondered if any could tell me exactly what im looking for ? also would it benefit me to change any of the other bits with this kit for better parts?
Hi there i have the same one,had it fora few years,i fitted a bmc cone filter,which is washable,never had any problems,i fitted the biggest filter i could get down there.dont know if i have gained any more power but it certainly sounds good.
unless you get it mapped to suit then you gain 2-3 pos horses but loose a fair bit of torque in my experience, when I had just a generic map I found the car pulled a lot harder with the std air box on, even with the OEM filter.
the sound is ace tho,
ok cheers, im geting a generic remap from jabba very soon, so would i be better off to change the panel filter for a good one and leave it at that,is it a noticeable loss and is it worth loosing the torques for that sound as nice as it is????
depends, I prefered the drive with the std box on, as it pulled harder,
Id just get a £35 pannel and smooth out the air box and leave it at that,
TBH unless you do the TIP there is no reall point as the TIP is narrow.
its up to you at the end of the day.
ok many thanks for advice, think ill just change panel filter for now.
i always make my own using 2.5 intercooler pipe and a decent shrowded filter works a treat and the power output on the toysport one is errrm optimistic!!! ha ha
