SD v SDHC v SDHC class xx
I have a number of SD cards and micro SD cards for camera, car stereo (smaller than CD's) and phones.
I have been given a 4GB SDHC card that does not work in the camera or the car stereo.
Looking on tinternet there now appears to be fewer and fewer SD cards available and more and more SDHC cards and also SDHC class ??
So what's the difference and why is it that SDHC don'e work in some gadgets? Is it going to be a case of gadgets being made obsolete by the rapidly developing memory capabilities :(
SD is max 2gb
SDHC 4gb upwards
Mirco SD is smaller version for phones etc.
IIRC
Older camers etc. sometimes don't support SDHC.
is it a micro sdhc card? if you want rid let me know a price.
SD is max 2gb
SDHC 4gb upwards
IIRC
Dont Forget the SDHC Class ??
The Class number denotes if it is a faster read/write speed. newer Tech will be able to tell you how fast it can read write, tally this up with the cards class, and you have fast tech.
Best way to describe this, When you take a photo on your digital Camera then the screen goes blank for a couple of seconds, this is the Camera writing the image onto the card, the newer tech which can take class 4 cards with a class 4 card, this blank screen will be shorter.
Baz I ran into the same non-working issues when we got a SDHC card with our Canon Digital SLR
Essentially it is a larger capacity card, as highlighted above, but uses a slightly different interface to communicate meaning the standard SD slot in your camera/car can't read it; but any SDHC slot will
so we could use it in an old laptop and the xbox while, luckily, the new one PC has an SDHC slot
