1.6 Fun Power Steering Pump
Hi, My fun started to make a strange noise when I got home last night, oil pouring out from steering pump, took it off tody and the bearing is shot.
Looking around for a replacement and not sure if they are all the same.
Does anyone know if a 1.6 felicia with A/C has the same pump?
Are they all the same fittings, looked on ebay and there looks like several versions?
Numbers on back of mine are 91 130 at top and 35 at bottom.
Thanks Simon
there are a few different types , keep your drive pulley as you may need to swap that over.
slight differance in where the pipework fits on some but that should be obvious from pics so just get one that has the main banjo fitting in the sanme place as yours.. i may have one kicking about if you are stuck
^^ there are a few types, but the pump from an a/c model felicia will fit yes..
on the a/c model the pump is rotated 90 degrees round relative to it's position on the non a/c model so that the outlet union faces forward, faces upwards on non a/c model...
the other types of pump are basically the same but they have a flare nut fitting instead of a banjo fitting but as far as i'm aware they never used these on the felicia, it was only the 1.0 and 1.4 polo's that had them iirc :wonder:
i've got one here too if you need it
