Door Lock O-S-R
Hi i cannot get my off side rear door to open or unlock. I have been told that it is a faulty door lock and I need to fit a new one, but don't know if this is correct or not. I think I can fit the new door lock myself if this is the case but How do you get the door open to do this? I would be greatfull of any tips or advice. Thanks
When my rear door c/locking failed I was lucky (sort off didnt need to open the door) it was down to the pollen filter leaking and corroding the loom.
Might be worth checking the wiring before you take a crowbar to the door......
I did read somewhere you can try and open and close the c/locking with the remote and pull the internal handle at the same time or banging under the door handle from the outside wilst unlocking and locking with remote. might also be worth a try.
Dont know if you can take the door card off with the door closed doubt it but some one might know.
Hi, thanks for info, I will check the wiring loom this weekend, i'm sure that will please the wife.
hi mate i just did mine,remove inside door handle,grab the pannel and pull,i only broke one clip,u then have to smash the lock with a hammer from inside the door to get door open,bit of patience and it will come off.
Make sure it isn't just the childlock being on doing it before you dismantle.
