Bolero - mobile phone audio in - 12 pin plug
Hi,
can anyone advise the best place where I can source a 12pin plug to suit the mobile phone handsfree kit audio in on a Bolero headunit?
its the same style plug as used for the aux line in, but sits along side it.
I installed on old Nokia CK7W into my MY09 vRS on the weekend, but speaker audio into headunit with car audio mute functionality would be a better way to go and sound clearer than the poxy nokia speaker muffled behind the climate control panel.
hope someone can point me in the right direction
cheers
Drew
You can get one from your dealer, its costs less than £1 if I recall. There are 2 parts, a holder and the block itself and it slides simply into the quadlock connector. If you have a CD changer then you should already have everything you need, except the spade connections which simply slide in.
Read though this OEM kit install and look at the end to see how thats connected to the car.
http://www.octavia-vrs.com/technical/bluetooth.html
and also this to see the wiring pinouts on your headunit (at bottom of page)
http://www.octavia-vrs.com/technical/mfd2.html
gee that wiring job on the bluetooth install looks like a dogs breakfast!!
cheers for the heads up, will try to see if my local dealer and supply the 12pin connector.
from there its easy... mute in, L+&-, R+&-.... piece of pi$$
cheers
Drew
im assuming these should be the parts im asking for at the dealer???
five of these
one of these
Edited by drew-8888
That's them - try a good ICE installer also as they should have them on the shelf.
OK, called my local dealer...
3B7 035 447 B green connector - AU$22.50 each!!!!
000 979 009 repair wire - AU$9.86 each!!!
how about go stuff yaself......
i take it the blue connector along side it in teh quadlock connector will fit in the hole too??
might try to snip one off a loom at the wreckers???
cheers
Drew
The black shell will be the same however the Green & Blue bits are keyed to stop them being inserted into the wrong slot.
BTW: You've got PM emoticon-0105-wink.gif
