Slight Engine rattle tdi
My 1,9 tdi 105 makes a hollow tapping noise when idle (for the last 8 000 miles).
It follows diesel engine strokes, but not every one it is irregular, more like "thum- thum - nothing - thum - nothing - thum- thum- thum - nothing" ...
The sound is best tdescribed as if the engine would knock on something due the vibration, but it dosen't vibrate.
Doesn't matter if I press the cluch or not.
It's slightly less frequent when i turn on the Aircon (due the engine load I guess).
I have heard exact same noise on a few TDIs.
My dealer says it's normal, and he can't hear anything . It can't be normal cause it wasn't there before!
Car drives fine.
Any ideas?
Cam-Belt touching its housing? Or broken generator/waterpump/ac compressor?
I have to check the cambelt housing, thanks for the idea. .
I believe the AC is OK,
it sounds if one of the belts has a wobble, but when I look at them they are all still and do not wobble.
(except the cambelt is the only one covered so I couldn't really tell..)
I don't know the sound of broken waterpump.. any way to test it at home?
Ah yes, my car thumps when i start it, as if one of the engine mounts is bad. Maybe it is related...
Edited by damok
Nope, not the belt housing.... Is there some heat shield somewhere at the center-bottom of the engine?
