Can you get Adjustable Top Mounts for the Vrs ?
With my car being lowered on Coilovers the front Tyres are scrubbing after a few thousand Miles on the inside edge , tracking & alignment is Ok.. But due to the lowering effect the camber on the front wishbones has increased & i am suffering the tyre wear effects ..
So can you get adjustable top mounts ?? Or has anybody tackled this is some other form ??
Dean
Im pretty sure KW do a set to use on their clubman series of coilovers. IIRC they are around the £200 mark
You might be able to use these depending on the spring size
Kw clubsport.
KW do some coilover that have top mounts , approx £1300 , but I dont know if they do them for the Fabia
No adjustable top mounts at all
believe me , I have looked in to it big style , as I have had so many issues with my Fabia
But I do know that there is a comapny that is looking in to this for me and you lot
Keep your ears to the ground
Sarah
KW
Ibiza 6L
Exactly the same as the fabia if its the tops mounts youre after
Cheers All :thumbup:
The Top Mounts are almost as much as the AP Coilovers :giggle:
Some intersting items here ...
Top Mounts
Dean
Edited by dfullb
  • 1 year later...
Any updates? I want adjustable top mounts!
D2 coilovers have adjustable top mounts, found on ebay for 600-700 quid
Or get some solid spherical bearing top mounts and get them welded in, go hardcore! Lol
