Engine problem when hot, Felicia 1,3
Hi!
I just had the temp sensor for the radiator fan and the thermostat changed on my Felicia 1,3 MPI -00. After the change the car looses all power after 10-20 min of driving. It run extremly rough and wont go above idle and when you give it gas it doesn't rev up but missfires. If left until cold it runs great again.
I have recently changed the temp sensor to the ECU and the spark plugs.
I've read on the forum and suspects the crank sensor.
Does any of you have any other guess?
/Fredrik
Edited by Freb
Take out the crank sensor (flywheel sensor) and wipe clean. These can pick up metal particles of the flywheel/starter motor gear.
