1997 1.3 mpi Felicia Idle problem
Hi,can anyone help with my wifes little felicia 1.3 1997.Basically when idling from cold or warm start it revs up and down on its own accord,if I disconnect the 7 pin plug on the throttle body(the cold start sensor?)it will tickover at level revs but it is too high roughly 1500-1700rpm.I have changed throttle body and gasket,cleaned all linkage,disconneted battery but nothing seems to get it back to normal,is a vagcom the only option?any advice most welcomed,many thanks
Edited by mollosc
I had the same problem with mine a few weeks ago and nothing solved it apart from VAG-COM, it needs the throttle body position reset
[Thanks for the reply I thought that may be the case.]
