door handle light bulb
one of my rear door handle lights isn working, anyone any ideas how to change the bulb in one??
I have one of my front door cards off so just had a look at the bulb location. Couldnt see what kind of bulb/LED it takes but it seems you need to unscrew the door handle enclosure from the door card to get at it.
Heres a pic of it from the back of my front door card.
Maybe of some help to you?
To get door cards off you need to remove the insert plastic from the actual handle bit to reveal 2 screws. There is a cut out in the plastics at the bottom left/right to get a srewdriver in to lever the plastic out. There will also be couple torx screws on the bottom edge of the door to remove, Then its a case of getting something inbetween the door and the card to pop the poppers off. Removal is pretty straight forward after that. :thumbup:
