Which engine oil for my Fabia 1.4 16V estate?
My 2001 Fab 1.4 seems to drink quite a lot of oil. I was told by the very helpful guys at my local car parts store that it's normal - modern engines use quite a lot of the stuff. He recommended Castrol SLX @
Errr well i don't think any new cars should be using oil! My Occy VRS has done 1K miles with me and not used a drop, and that is not nursing it. Look in your manual to get the recommended oil and stick to that. There will be a few choices but if you get one that comes up to spec use that, or get in touch with Oilman on these forums and he will help you. :)
The dealer will have been referring to Castrol SLX LongLife II which is a 0W-30 oil. That oil is only suitable for engines specifically designed to use it - which in the case of the Skoda is those which can be set for variable servicing.
  • Sponsor
Ok,
VAG Group do everything by codes, in your handbook it will give you some codes for the oil to be used in the car, it will look a little like VW505.00 you will then need an oil that meets this VW spec.
