more fault woes
For a while now.. starting has sometimes been an issue on the vrs and this morning it was worse and took longer to fire up
Also
over the last 2 weeks cruise control has stopped working..
Then started again on return trip from work.. last weekend it was on skoda's diagnostic machine.. and no faults where reported
After 2 months or so of owning the car.. im really getting fed up
Any ideas anyone? any oil/ treatment to try for starting issues?
Is the CC a faulty stalk?
Have you done a battery test?
looks very similar case
car is at the stealers this sat for the front shocker replaced under warentee.
When they checked for fault codes last time.. nothing was brought forward.. so.. erm pass
/me starts to think .. i should have bought the scooby lol
The RAC chap that came out to mine couldn't find a fault, but then it reported a failed heated front screen, which is surprising as I don't have one! Very odd..
They later found fault as described..
Still doesn't make any sense to me... !
Good luck with it.
Car was in yesterday.. Forgot to mention again abut the faults dam it..
Cruise control has worked since and sometimes starts on the key.. Any mix you can add to fueling to help with the starting ?
or is it normal lol
