hid bulbs
bought a 6000k hid kit a while ago and it only has the single filament bulbs so the hi beam doesnt work.is there anywere i could get some duel level bulbs from?
its a vip slim line ballast kit if that helps
search ebay, they have replacement bulbs and the connectors from the kits i have seen all look the same so should fit your ballasts
had a look on ebay and cant find anything
find sellers who do hi/lo kits and ask them if the sell bulbs alone, if they dont you will need a new kit i guess
I have bi-xenon 4300k kit.The bulb has 1"filament" (xenons doesn't have filaments)....
low beam is normal like any other kits ,and on the high beam the bulb retracts 1/2 inch like here
you can fit bixenon bulbs but for 2 beams on the same bulb....but won't work,you'll need a relay and some additional cables to shift between high and low beam
