A few Q's
Ok, so in the process of installing power and cabling for my satnav and I've damaged two of the plastic covers for the 'function buttons' just above the radio. I don't know what these are actually called but it's where rear heated window buttons and the like go. What I need to do is get a couple of the plastic covers that go in the unused slots. Does anyone know the part numbers or where I could get some?
Also, I had a second cigarette lighter fitted, I asked for it to be placed 'in the dash' (meaning inside the housing) but the mechanic drilled into the dash and fitted it flush (my fault for not explaining properly). I'm going to remove it and use it as intended, but i'm left with a massive hole where it went. Does anyone know of any plastic covers which are used to block cigarette lighters in cars which are shipped without a lighter. If it's in the beautiful grey of the fabia interior it'd be a bonus too!
Cheers guys
Lou
Thanks for the advice, I got the replacement button covers ordered, found the part number needed, £3.50 in total!
That grommet site looks like it'll do the trick too, thanks!
