Rear Wiper Removal
I was planing dewpiering the rear on my octy vrs, i was wondering if any of you guys have done this and what is involved in doing it? is it easy to get the motor off?
Also what size of rubber gromet is required to plug the hole?
Paul
hi mate, fairly easy to do. wiper arm off from the outside, remove plastic boot cover inside (be wary of the clips) then un bolt the motor and tape the wiring up.
use a 24mm bung from halfords it comes in a pack of 3, 19mm, 24mm and 25mm costs about £1.79, also put a bit of sealant on the bung before you fit it to stop any water getting in :thumbup:
HTH
Thanks for the useful tips guys, will be doing this mod at the weekend
cheers
paul
