HELP...
Help...
My Octy VRS has just failed its mot on emissions... they reckon its the KKK turbo which has gone, as it is using excess oil and smoking...
Where will i get a replacement reconditioned turbo... and how much will it cost me
H E L P
try CR Turbos for various options of rebuild, exchange, etc.
Very helpful and knowledgeable bunch of guys.
Edited by richm
Help...
H E L P
I would still get a diagnostics done to confirm you don't have any other issues causing emission failure, unless the garage did this and the result was turbo based upon the logs
Could be expensive replacing turbo if something else caused failure. Mind you if you know turbo is on the way out then you will have no option but to replace it anyway.
